Just to let anyone who might need spares for these air compressor pumps I have found the following information that might be a help.
From an earlier link it was mentioned that a firm in Manchester were the Uk importer of these Italian machines. Their number is :- 01617938127. You have to ask to be put through to the Fiac Air compressor section. The chap who seems to know about these pumps is called Martin. He can help identify a pump if, like mine ,there were no data plate. Bore and stroke, pulley dia. and number of pistons sort of stuff. He can give you the part numbers if you know what you want but they do not supply to the general public. If you tell him your post code he will tell you the company that is their agent. Mind you, in my case I found out that the info was not up to date and that they had ceased being their agent some time ago and were now Sip agents! But luckily for me they were able to tell me who were the agents now. In my case I then found out that even they have to have a minimum order value of £25. And as the bits I wanted were about 50% short of that they would add mine to the list and when they have a sufficient amount they would get the bits in for me. SO, to sum up. The bits are available but it is a bit of a minefield.
I hope this tale will be helpful to some one.
Regards, Michael T
Regards, Michael T
