only problem with plasterboard is damp the only real solution is sheet steel try to find a stockist with some damaged sheets you dont have to cover full walls
My workshop is mostly timber, 22mm exterior ply with cls framework, then clad with 12mm plasterboard and the cavity filled with fire rated expanding foam, I havent managed to burn it down yet.
Im in a 7 x 12 wood shed double skined. Depends on how much welding you do realy. If its only small projects I dont see the need to worry, I keep a bucket of water handy, my benches are all wood, my main area for welding I have a thick piece of steel plate on top of the bench and my other bench is a Kitchen work top, the laminate top will take alot to burn through.
Im still alive, BUT I take no responsibility for anyone doing the same, lol....
