Grrrmachine
I just want to confirm that I understood the technique for spraying 2k metallic, before I go out and ruin a panel. Test panel is a sunroof, wet-sanded with 600.
1) Spray one coat, not too wet but not too dry, in a single direction with 50% overlap
2) Allow to flash off (15 minutes)
3) Spray second coat exactly the same as the first
4) Allow to flash off (15 minutes)
5) Spray mist coat at angle to original coat
6) DO NOT TOUCH the metallic coat. No sanding, flatting or tack clothes.
7) Apply two light coats of clear. Allow to flash.
8) Apply two more heavier coats of clear.
9) Wait up to a month before doing any polishing, buffing or waxing.
What I'm not sure is, how much time do I have between spraying the base and the clear? Some places I'm told I MUST wait 30 minutes, to let solvents out, other places say no more than 45mins otherwise the flakes settle too much.
