ChrisBenoy
New Member
Hi all, been reading this forum for a while and have read a lot, just had my first attempts at welding some metal together, would be nice to get some honest opinions on what i'm doing wrong/any setup changes I might need to do.
Have been working on classic cars for a few years so it has always seemed like a good skill to have. I suspect almost all the welding i'll be doing once I get good enough will be on thin bodywork (0.8-1mm steel) so this is what I have started to learn with.
I realise that its probably a fair bit easier to learn on thicker metal but I thought i'd give it a go.
The equipment (which actually all belongs to my dad) is a SIP Migmate 105 turbo using 0.6mm wire and an argon/co2 mix (couldnt tell you what percentage, i'm guessing something fairly standard) at 10 LPM (in a garage) I gave it a service the other day as it hasnt been used for many years so it has a new tip, shroud and liner (sadly only a plastic one so far). I am also using an auto darkening helmet (great piece of kit). I realise that this isn't the finest welder in the world but it should be ok on thin metal and it seems to be working.
I started off using the lowest power setting (1 of 6) and about medium wire speed, this would work but the penetration was a bit intermittent with too much weld building up on top, I then tried 2 of 6 and this worked much more nicely.
I haven't taken any pictures of my welds on a flat piece of steel, it seems like so long ago that I did them (3/4 hours?) all the pics are of my attempts to butt weld using the thin metal technique.
This one started nicely but I ended up making a hash of it due to the wire feed not running very nicely, I loosened a few things off inside the welder and that seems to have fixed it. Too late for this weld though.
This one looked fairly neat but didn't penetrate very far. After this was the point when I turned up the power on the welder.
With the power up it seemed to weld better. Not exactly neat and tidy but an improvement?
I then decided to do another double sided one.
This was the last one I did, I finally realised that I wasn't overlapping the stiches as much as I needed to to get a good finish. This was only a quick run but it worked better than most the rest
As you can see from the photos these are just a small selection of the welds, I had cleaned up an offcut of a car panel and just cut that up and welded random bits that lined up together. I'd like to hear everyones opinion on how I can improve.
Thanks,
Chris
p.s sorry for the long post.
Thanks,
Chris
....if your bodywork man is approachable ,try and spend a day or two with him,offer to come and make tea
.....you will pick up tips on making patches,distortion,finishing etc ,will speed up your learning considerably ....if the fella is retireing i expect he would be happy for the help.....just a thought
