DennisCA
- Finland
Decided to make a dedicated thread for this.
Before christmas I brgouth this home, for 40 euros I thought it was worth the price of the motor if it's not salvageable. But I would like a working high pressure washer of better quality than the usual consumer level stuff.
Water intake on bottom, four pistons of some kind that build pressure, the high pressure output is on the top. It doesn't seem to be going from one piston to another for sequentially higher pressures, but to all four at once and then to a combined high pressure side.
Brass construction, can't see no cracks.
Motor off:
I did find how the valve that returns the water to the stream works, it was actually shown in the previous photos. Orange colored part, hex shaped.
Removed the cylinder heads, doesn't look very nice inside...
Vacuumed it out
Took apart a 2nd cylinder, similar but better shape
Both seem to have rusted out in the middle around the center holes. The center hole is threaded and I think the cylinder is attached via the hole.
The pistons look like they might be plated with something that has started to release. I think hard chrome.
Cylinder tops looks OK. Next step is to contine disassembling all the cylinders. Some kind of rubber washer.
Motor off:
Vacuumed it out
