Hi Folks,
Back in March I needed info on fittings for a John Guest nylon pipe system.
Response was great, and I was able to run my pipe system around the shed.
Believe it or not I'm only just going to connect the compressor (SIP 06290 Airmate belt drive 3hp 150L) to it, 'cos other things have had to take priority!
Anyway, my problem is sourcing a flexible 22mm. pipe to connect (I know I need a 1/2" fitting at the compressor end) to the 22mm JG rigid nylon system.
I've been searching the internet, and trying a local hydraulic pipe supplier with no success.
Any pipes or hoses available seem to be too big (28mm. OD0) or too small.
I don't want to go any smaller with a flexi pipe, because surely that would negate the advantages of the 22mm system?
Any advice or ideas please?
Tony
Tony
