roofman
Purveyor of fine English buckets and mops
- North West with water on 3 sides
was working perfect on mains 3 phase and then we moved to another address and wired it to a 50 KVA Genset and had it perfect for a day and now failure light is flashing..Have you confirmed the correct rotation direction if its new to you?
I can recommend The Compressor Man. http://www.compressorman.co.uk
nice thinkingIf you get desperate to get work out do you have a local plant hire company.
https://www.speedyservices.com/19_0070-h-silenced-road-compressor-diesel-twin-tool
Whenever I specify or fit a compressor I always have a tee and valve ready for standby or rental compressor to allow for a fast connection.
I think your compressor probably can’t handle that duty cycle mate.motor is star delta connected and frequency 50 and voltage is bang on on all phases and collectively..had the blasters working for 2 hours solid today and comp was getting hot but seemed normal then stopped for a cuppa and would not restart going to have to call someone in it looks as we have work stacking up
Its been working with the same blasters for a year in last address with no problem..in fact it has a 2 meter high stand up tank and with the blasters going it maintains 10 bar in the tank mate...belter of a machine but atm its got the fluI think your compressor probably can’t handle that duty cycle mate.
Constant run compressors that can handle that kind of CFM are not cheap.
See them in power stations all the time. Big buggers.
We run a road compressor for blasting. 140cfm.
Oil cooled.
Think you’ll have to get someone in then mate, something has obviously gone wrong inside it.Its been working with the same blasters for a year in last address with no problem..in fact it has a 2 meter high stand up tank and with the blasters going it maintains 10 bar in the tank mate...belter of a machine but atm its got the flu
