Noods
- Ipswich
Hi all
I’ve a Parweld XTT 220 AC/DC pulse Tig welder and parweld foot pedal...
My Q is this..
When the torch is directly connected to the machine I can adjust all the parameters..
But when I connect the pedal to the machine I can only adjust slope pre and post..
I fully understand that this is what the pedal is for eg to increase and decrease current..
But if I want to use for example pulse, I have to connect the torch, adj everything then remove it again and connect the pedal again before use.. also any re adjustments I have to go through it all again.. annoying..
I ask, is this the norm or am I missing something here..
This is the first unit I’ve had with a pedal tbf and the instruction books are as good as useless..
Thank you..
My Q is this..
Thank you..
