Not sure if this is the best section for this question but please feel free to redirect it if required. I was given a 5 ton Tirfor winch which has been sat unused for many years with a cable threaded through it. Everything was badly seized and the cable wouldn't move either way. I've split the casing and cleaned as much of the mess out as possible (hardened grease, mud, rust, acorns, straw, dead mouse etc but to get the cable out, I had to cut it. Managed to then get both forward and reverse clamping mechanisms to work so it's now all back together.
The original cable is generally in good order but I need to put an end on it so that it will be possible to feed through. The original end that is on the 9" section that I had to cut-off looked to have been welded and than ground into a slightly conical shape. Anyone done this before and if so how. I've had a look on the net and can't find anything really relevant. Cable is about 1/2" dia .
