vectraross
anyone seen this on youtube about making a small comp out of a fridge comp? are they safe could it be made to work like a normal compressor cut out and start up again?
The gas cools the motor not lubricate it, the oil does thatI remember reading somewhere it used the refrigerant gas to lubricate the moving parts same as a car air con system
sopose a fridge isn't going to be useing much oil, th ediesel jobbie was off a wagon unit wanted a fair bit
WELL I had the exact same make and style but its bigger brother about 35 yrs ago absolutely brilliant quiet but powerful the inlet air goes in the crankcase and up through the read valve in the piston.For 40 years I had a butchers fridge/cold room compressor pump unit,only sold it a few years back to buy a higher capacity one,And before I acquired it and made a receiver it had done many years service doing it's originally intended job. Pump unit was a york shipley made in the USA, Very robust well made bit of kit, Only ever fitted one set of rings in all that time and the bores were still perfect, Could not get the correct rings so I machined the grooves a few thou wider and fitted a set of cords oil control rings, They worked even better than the originals, Here is the little fella in question after a refurb prior to selling it, (complete with tupperware sponge filled air filter)
