Hi i am new to this so be gentle with me,
I have a snap-on mig everything works fine wire feed button ,trigger on torch works but when you try to weld (strike an ark to earth) the fuse in the 13 amp plug blows does anyone have any ideas?
thanks Sean
the rectifier has 2 components that look like diode packs,they look the same but test different with a meter.does anyone know if they should have the same characteristics?
part no MDD90-04 A8927 ART NR 64.0065.04
cheers sean
Each module has 3 terminals,looking at the diagram on the module i measure across each diode and get a reading of 12.7k but on one module have no reading across one diode.
i guess that's the duff one.problem is i cant find this part anywhere and don't really know what to look for as a replacement
