It's a female thread, and the nearest size it will allow you is 18mmIf it’s a male thread create a cylinder 19mm in diameter then with the thread command select the cylinder as the body to thread also select the modelled option otherwise it won’t print the thread correctly
I'd love it to be a standard thread, unfortunately I didn't make the connectorI looked into this a long time ago and then never really used it as nearly all the threads I do are standard.
If I recall I needed to download and install a plugin.
I manually edited the thread xml for some custom threads I do.Long shot: is there any option to make a 3/4-26 thread?
See also: https://knowledge.autodesk.com/supp...fdcarticles/Custom-Threads-in-Fusion-360.html
It appears from the above that you can edit an .XML file to make it do what you want.
3D model of a male thread of the correct spec. here: https://grabcad.com/library/mushroom-emergency-push-button-1
Possibly, the 3D model here might containthe thread: https://www.accu.co.uk/ring-thread-gauges/442613-JBO-RG-500399
I recently did it like this in inventor and it worked for me.A bit long winded but in Onshape you draw a helix around the cylinder and sweep remove a triangle to form the thread. Change the shape to create any thread form.
