Assume it's got tapped holes in the crown of the piston for when you wanted to lift out of the block? If so , and if you intend to keep it upside down as per the picture, you could make it harder for the pikeys to pinch
View attachment 167705 Why have a sundial or a stone trough when you can have this in the middle of the front lawn. This should get the neighbours talking
it's got a cast iron crown on the piston there is a ring of bolts inside the piston under the pin so i could bolt it down easy. i don't know which way up i'm having it yet i'm still thinking about it it's a project for the spring
have it the correct way up and stick a sun dial on the top..its excellent, please dont start a trend though,as I make my living(?) from casting sundials/troughs/birdbaths..ha!
