IS the machine powered up ?Hi I’m new to this I have a snap on 130 turbo I have just bought second hand as I have attached the gas it is leaking out of the torch and will not stop
had one of these its not that bad for the money only thing was an extra cable in the sleve but a member pointed me the right way to wire it and worked very wellAs above, the standard torches on these arent very good, if the gas is flowing where it should be and not leaking out everywhere you could arguably just add a solenoid inside the machine that operates off a switched 240v supply taken from the power switch or pcb connections.
But really replacing the whole torch and lead should be pretty straight forward and cheap, the smaller "14ak" style torch and lead is what you'd need as its the one with the integrated gas valve unless you want to upgrade to a euro torch and socket, but thats a whole other ordeal.
