Memmeddu
- Italia Sardegna
Hi everyone, after having bought a plasma cutter , I have to buy an air compressor.
But it's a Next month expense .
I have already found an in-line water trap and I'd like to add an air hose to the cart .
I've seen that there are various tipe of hoses , and I'd like to buy the better quality I can .
So I need advice about
IP Air+ INsight Tubo Aria Compressa in PVC 10mm (3/8") x 10m Fluorescente Verde per alta visibilità Incl. raccordi rapidi Verde per alta visibilità Incl. raccordi rapidi https://amzn.eu/d/dI971cX
STIER Tubo aria compressa SSDL-10/10, lunghezza 10 m, diametro interno 10 mm, diametro esterno 15,5 mm, pressione di esercizio 20 bar, compatibile con i compressori più comuni https://amzn.eu/d/3VkTppY
ECD Germany Tubo Flessibile per Aria Compressa Lunghezza 10 m 20 Bar per Compressore in Gomma Pneumatico Diametro Interno Ø 9.5mm Diametro Esterno Ø 15mm Tubo a Pressione con Attacco Rapido Nero https://amzn.eu/d/6pHzbYK
Poppstar Tubo aria compressa attacco rapido 15 metri (PVC ibrido con tessuto, raccordo rapido) tubo compressore aria 20 bar, blu https://amzn.eu/d/0O538of
I was thinking about one of those but if have a valid option I'm happy to hear it
It will not be used only for the plasma cutter.
I'll make my personal set of air tools in the next future (die grinder,air hammer, etc)
Thanks in advance
Thanks in advance
