Pollys13
- Wiltshire UK
The grit hose has a 10mm bore, 2.5mm nozzle bore, hose is about 6 feet long with a gentle bend and going up into cabinet. Using 120 mesh S/C grit Have water trap on main regulator going into system. 90L Compressor is set to 90 PSI, the pot 40PSI, 65PSI. The grit seems bone dry to me but is, seems..... deceptive? If only a minute of moisture get into grit can that cause it to clog?
I checked the system and it was the grit hose blocked, not pot ball valve or anything else.
Any advice appreciated,
Cheers.
Cheers.
