Burdekin
Chief Bodger
- Aberdeen
Morning Folks,
I have a cast iron head I need to do some grinding on. My dynamic compression is going to be too high and adding a thicker gasket would probably also cause detonation so I need to make the combustion chamber larger and while I'm there probably do a little work on the exhaust post as it doesn't flow anywhere near as well as the intake. Anyone recommend a die grinder, and carbide burrs (long and short) etc for the job? Not too expensive would be ideal.
