BrokenBiker
- Newport, South Wales
right. after going through endless hunting knives over the last few years I have decided to make my own out of a file.
have even bought a brand new file for the job too, as it was only £1.20 on eBay.
anyway, the question is, will a go systems butane/propane mix blowtorch be enough to firstly anneal, then re-harden and then bring it up to temperature to temper the steel?
estimated max temp is around 1300 celcius and the nozzle is around 15mm dia and 30mm long. can produce a blue flame the dia of the nozzle and around 30-35mm in length on full flow.
will it do it just from holding the steel in the flame, or will I need some form of breeze block set up to keep the heat in?
