macplaxton
New Member
Hi,
I'm just preparing to get back into welding having just dusted off an old Snap-on 130 I bought on eBay approximately two years ago.
Many moons ago, I had a BOC 130 turbo and a few years back did a little bit of work with a Cebora 130 (All the same thing in different suits I know)
Having spent some time yesterday removing manky wire from the outside of the reel, I tested the wire feed and it was rather poor and erratic. However, wire speed was back to smooth and even when I clean the blackened contact in the brass block / gas valve trigger.
Managed to borrow a pipe and hook it up to some Argoshield Light and lay down some test welds on some scrap 1mm steel. Welds not the best, but I wasn't blowing (too) many holes in the sheet. Satisfied that the welder is fully functional, I was thinking about converting it to a Euro torch as the trigger isn't all that great. I'll probably change the earth clamp too whilst I'm at it.
Other than that I need to see what the prices are for AP or BOC round here. Need to get a decent size of cylinder as I've a lot of car panels to weld.
I'm a bit out of practice so will be asking for advice.
Cheers
Cheers
