Hey guys,
My work got a new compressor and let me nab the old one. Unfortunately I've not a clue how to get it setup correctly. I bow down to you guys to show me the ways of the compressor master.
I plan on getting a few air tools, like a rattle gun and a (very) small blast cabinet for small car parts.
More pics!
1. Compressor in situ.
http://i.imgur.com/2HEd685.jpg
2. Moisture trap
http://i.imgur.com/fuqO8Yn.jpg
3. Moisture trap outlet #1
http://i.imgur.com/mcYWMlc.jpg
4. Moisture trap outlet #2
http://i.imgur.com/jmsicqR.jpg
5. Moisture trap inlet
http://i.imgur.com/MTYxoSO.jpg
6. Compressor Outlet #1
http://i.imgur.com/NdGAQhV.jpg
7. Compressor Outlet #1
http://i.imgur.com/Ggn7WrZ.jpg
I want to order everything I need to get up and running but could do with an expert's assessment on the connections? To my untrained eye it looks like...
- 1/2" BSP outlet from compressor shut-off valve to 1/2" BSP inlet on the moisture trap / regulator? Do I just get barb fitting adapters and cheap hose?
- Weird outlet connector on the moisture trap / regulator - is it some sort of quick release connector? Do I stick with it or replace with barb and hose?
- Moisture trap will split to a few valved connections (manifold or just T pieces with valves?). The first will go direct to the blast cabinet (which will be right next to the moisture trap / regulator). The second will go to a lubricator then retractable hose and only be used for tools. Maybe a third go to another retractable hose and be used for dusting off and filling tyres?
Would really appreciate any recommendations and suggestions on what fixtures/fittings to get.
Thanks guys!!
More pics!
2. Moisture trap
Thanks guys!!
