Hello,
You have probably had this question asked many times but what is the best compressor I can get for a budget of a max £200.
I have been reading and seem to get two views you need at least 3hp compressor (which seems to be out of my budget) or you will be fine with a small compressor.
I am wanting to spray all the little bits (backing plates, axle tubes etc) from my beetle as well as spraying my chassis and areas I have worked on with epoxy primer. I am not going to spray the whole shell this is going to be done professionally. So the biggest spray job will be the chassis.
Can anyone recommend a compressor which will meet my needs and a spray gun.
Regards
Elliot
Regards
Elliot
