Hello, I am new to the forum. I have a Hydrovane 501 that has been in use for over 15 years without any problems until a couple months ago with the drive coupler between the motor and air end shattered. I replaced the parts with new parts and thought it would be a good idea to rebuild the air end considering I had the unit off. I found the only 'professional' compressor shop locally and took them the compressor along with the rebuilt kit. To make a long story a little shorter, I finally picked up the compressor after 9 weeks. I now have an oil leak around the oil cooler after it reaches the cutoff pressure. The leak is usually only a few drips until the internal pressure bleeds off. The compressor does not have the same cfm capabilities that it had previous to the rebuild. Taking it back to the compressor shop is not an option! I am completely comfortable working on this myself. I would appreciate help or advice.
Thanks
Thanks
