Freshfabrications
www.freshfabrications.com
Hi Matt,
I need some help regarding my V30 AC/DC machine which is about three years old.
The machine as you will know is water cooled and supplied with an excelent WP18SC torch, all fitted with quick connect locking coolant fittings and the usual DINSE and controll connector.
Was doing a repair on a cracked crank case bolt hole and I noticed alot of coolant on the floor, I checked thuroughly and traced the problem, the hot hose that exits the DINSE connector and takes the hot coolant from the power line back to the machine has a leak in it about half way along the hose.
There is no visible damage, abrasion, holes etc etc, nothing at all?! It's just leaking from one spot. I treat my machine better than my GF, much to her disgust, so I know it wasn't just some dummy manouver on my part.
I'm NOT after a free repair here by the way just advice.
What I need to know is what series or type or brand is the male part of the quick connect fitted to the torch hose. I know if I cut back just past the leak I may be able to re connect the male fitting, but just incase I can't get the cable crimp off with out killing the fitting i'd like a spare or two!!
Can you help?
Would also be awsome to be able to get another lighter torch and know what fitting to use/order for the coolant so I don't have a load of clunky fittings banging up my beutiful machine!!
Cheers
Can you help?
Cheers
