stretchie_
I have just picked this petrol compressor up
I saw it running before I bought it but I'd like to give a quick once over before I start using it, change oil and sparky for the motor and the oil for the piston too.
I've only ever had a lidl compressor so after some advice please, the motor is easy, there's loads of info about the Honda CG160 so that's not a problem but I have not idea what kind of oil to go for for the compression cylinder, any ideas?
Also, on the Lidl compressor there is a little pull switch on the regulator which you can pull to release pressure from them compressor then a bolt on the underside which you can undo to let any water out of the tank.
This also has a tap on the underside for water release but I'm not sure about releasing the pressure from the tank, any ideas?
Some more pics if it helps
The compressor pump appears to be a Chinook K17?
Also, I know the tap at the back (which is closed in the picture below) should be opened for easy start when starting the compressor particularly from cold, there is a sticker on the back saying so
But would any of these be a pressure release bolt?
Thank for any help
Thank for any help
