Hi,
I have just had a Clarke SE16c100 compressor delivered.
Can any wise 'sages' on here offer some advice on how to :
1. Set up the electrics.
2. Set up the pipework
1. Electrics. - I was expecting to be able to put a 13amp plug on it and away to go but the manual is saying it needs to be a 30amp supply.
Can anyone please advise me how to proceed.
The building where the compressor is going to live has a modern trip switch electrics board with circuit breakers.I have previously wired this myself so know that there are spare slots for a 30amp CB if necessary.
Do I run a new dedicated cable for the compressor ?
What cable thickness is needed
What connections do I put at the end of the cable and on the compressor flex cable ?
Does there need to be a fuse in that line somewhere or will the Circuit Breaker do that job ?
2. This particular compressor has its air feed coming straight out of the middle of the cylinder and looks like its intended for 1" iron.
I wish to use the compressor for auto painting and some use with air tools so can anyone please recommend a set up that includes pipe dimensions/fittings with sizes etc suitable for that use.
Also, I require a regulator / water trap in the line and these are available in several different sizes for different connections ( 1/2", 3/8" 1/4" ) what size is recommended in order to supply the amount of air need for my uses. ?
Also what quick connectors are recommended Euro or PCL ?
Any help or pics of other peoples set ups or redirects to existing posts would be much appreciated.
Thanks
Thanks
