AdamWatson
New Member
- Southern UK
I have an old Hydrovane 13 that I'm trying to get going. The previous owner didn't have enough power to run it. When I connected it it would run for a few seconds then trip the contactor. We thought maybe the contactor was bad so replaced it and the relay. Its still the same. I intend to drain the oil and refill bit what should I use to replace it and what else should I check? It has a 3hp single phase motor and I've connected it via a dedicated supply run in 10mm t/e on a 20amp d curve breaker
