Hi all,
Firstly hello to everyone, I came across this forum in my search for information on home made compressors, there seems to be afew threads that have toyed with the idea, and some even briefly mention a rather interesting idea, making a compressor from an old v8 engine...
Its this that interests me the most...
for a long time I've wanted the equipment to sand blast with, a big enough setup to blast parts of car bodies (like wheel arches and floor pans) and motorbike frames with...
Making a home made blast pot seems straight forward, using an old propane tank, some black iron fittings/pipe, leaver valves and a regulator.
But the problem it all boils down too is the high CFM's required to get the pot to function really well and use a decent sized blasting nozzel, hydrovane compressors are lots of £'s and I don't think I've ever managed to find a cheap pump going secondhand, theres afew hydrovanes from time to time, but never a piston pump, not anything above 30CFM
a diesel towable compressor is going to cost at least £1,000 and its going to be an old one at that
So I've got on to the idea of making a compressor using two 4 cylinder engines
I have lying around, pulled from an old 1998 ford transit a very simple mechanical 2.5 diesel engine (only has 1 live wire for the fuel solenoid besides the starter circuit electrics wise) so would be really simple to run up on a bench or stand...
I'm wondering why I cant get my hands on a simple 4 cylinder engine made from cast iron (something like a ford pinto) and some how stop the exhaust valves opening (maybe grind the cam lobes down with an angle grinder, then thread non return valves into the spark plug openings...
mount up the correct sized sprockets to the flywheels of the two engines and link the two together with a chain
using some 10mm or 15mm copper tube make up some kind of outlet manifold from the non return valves, send it into a pilot unloading valve of some kind (ive found these really easy to find on their own for petrol compressors with a built in engine throttle control)
http://www.ebay.co.uk/itm/GAS-AIR-C...913228?hash=item415059714c:g:aZgAAOSw~gRV6ErI
If these compressors based on old V8 engines put some out seriously high cfm's (so I've read)
This should work rather well?
What do people think to the idea? How many cfm's would a 2.0 4 cylinder car engine make?
