DAPPH
as dyslexik as I'm daft
Can anyone help or advise please ?
Has anyone used or built a simple home made shaper powered or hand driven to gouge out teeth in ally , brass or steel , as I'm looking for ideas to make my own thread indictor counter gearwheel on my lathe using the 360 degree indexed head stock gear wheel as the divider to give me 16 teeth on a 3/4 inch O/D turned up blank .
I don't have a tool post grinder and in any case wouldn't know how to source the correct cutter profile, though at the end of the day may be able to convert an old drill press to try using one ( help on that alone would be useful ) .
I remember seeing one in about 1961 at school that looked like a simple pivoting hand lever with a tool carrier in shouldered guides , it had a roller bearing back end touching operating lever handle some return springs or elastic to recover the shaper once it had passed over the work piece .c .
I seem to remember that it was only used for brass & a base metal like cast zinc for that was the major component of the engine & flywheel .
We were building a nine inch long x 4 inch dia boiler stationary steam engine at school as part of an integrated science , physics & mathematics project where we worked out he calorific value of different fuels and the efficiency of the engine for each given fuel .
The shaper tool carrier was set in two slots in the 1/4" thick base plate which was held in a vice & the carrier was moved across the work piece with a pair of fine thread thumb wheel.
If any one can point me to such a design of scraper or put up some pictures of a sensible hand operated shaper I'd be very grateful
Dave
Dave
