Hi, as a few of you may remember, I had a thread up a while back about buying a generator which concluded with me buying a 4kW Honda item. Since then, I've bought a welder and another generator which is the one I'm going to use, for the princely sum of £30. I'll be fixing up the one I bought first and shifting it on, if anyone here is interested
. The new
one is only about 2.7kW output and pretty ratty looking, but it's more than enough for what I need, and more importantly this one actually has a 230v socket.
However, the reason it was cheap, is that the recoil start
doesn't work, but I didn't think this was a problem as I could just swap the ones I have. How naive. The 'cup' that the starter engages with is different between both, as was the the mechanism inside. The starter on the new one doesn't engage at all through the whole length of the cord, regardless of how fast you pull it. The other one I put on, would try to engage and slightly catch, but then slip. I managed to bodge the two into one that would work, but was not ideal
as it was slowly mashing up the arms on the starter and they'd occasionally pop out, requiring disassembling, fixing and reassembling roughly every other start.
They're all pretty ******** now and I'm looking to just buy
a new one, but there seems to be so many options on ebay
so I'm looking for advice from people that know more than me on which to buy. These are the ebay listings
: http://www.ebay.co.uk/sch/i.html?_f...60+.TRS0&_nkw=honda+gx160+pull+start&_sacat=0
Picture dump:
The mechanism from the new one (it does have two arm things, one fell out):
IMAG0339 by photos
/96761286@N04/]William Brownston[/url], on Flickr
The old one:
IMAG0337 by William Brownston, on Flickr
You can see how the arms fall out, the slot
the the 'cap' allows it to flex and release the teeth.
IMAG0338 by William Brownston, on Flickr
The 'cup', approx. 68mm diameter, protruding from the casing 20mm, with four square cutouts at roughly 15mm^2 each.
IMAG0340 by William Brownston, on Flickr
If anyone can see which would be best to buy on eBay, I'd appreciate it.
Thanks.
. The new
one is only about 2.7kW output and pretty ratty looking, but it's more than enough for what I need, and more importantly this one actually has a 230v socket. However, the reason it was cheap, is that the recoil start
as it was slowly mashing up the arms on the starter and they'd occasionally pop out, requiring disassembling, fixing and reassembling roughly every other start. They're all pretty ******** now and I'm looking to just buy
: http://www.ebay.co.uk/sch/i.html?_f...60+.TRS0&_nkw=honda+gx160+pull+start&_sacat=0Picture dump:
IMAG0339 by photos
/96761286@N04/]William Brownston[/url], on FlickrThe old one:
IMAG0337 by William Brownston, on FlickrYou can see how the arms fall out, the slot
IMAG0338 by William Brownston, on FlickrThe 'cup', approx. 68mm diameter, protruding from the casing 20mm, with four square cutouts at roughly 15mm^2 each.
IMAG0340 by William Brownston, on FlickrIf anyone can see which would be best to buy on eBay, I'd appreciate it.
Thanks.
