Neighbour asked me to look at a rotovator. Says it was running fine, then started running rough and cutting out.
I have so far stripped the carb as much as possible, left in the ultrasonic cleaner for a while, and checked all jets were clear giving everything a good blow out with carb cleaner and air.
Tried a new spark plug.
Cleaned out the tank and filter as there was a little dirt in it, even though plenty fuel runs out the float bowl drain.
Tried fresh petrol.
It will start first pull, but with the choke off hunts at full throttle.
A little bit choke and it runs nicely. At idle, it will just die unless the choke is on.
I'm not sure what to check next, as every major engine fault I can think off, would either make it hard to start, or run continuously poorly, unless there is something cracked/holed/gasket blown between where the carb bolts on and the cylinder head, but there wasn't anything noticeable when I had the carb off, but there was still another cover in the way.
So anybody got any suggestions?
Tried fresh petrol.
