I think you’d need to know start pressure, end pressure, volume of tank and the consumption of the tool. The end pressure would be important as it’s going to get to a point where there is still pressure in the tank but it won’t be enough to drive the tool?How do you calculate how long an air tank will last running a specific tool?
^^ this really - if you knew the relationship between volume and pressure you could calculate it with some degree of accuracy but nothing like trying it for real.Fill tank, turn off compressor, time how long said tool runs.
only if he had the tools allready then he would allready know thatFill tank, turn off compressor, time how long said tool runs.
forget it with a fridge compressor better to have a belt compressor or a 50 litre compressorThinking about making an air tank from a 47 kilo gas bottle with a 12 v fridge compressor that will run off my solar panels, the only air I need is for a 30 amp plasma cutter which I don't use much, how long would the tank last i have no idea.
