julianf
- devon, uk
I have a compressor - small belt driven thing.
Prior to my ownership it was reterofitted with an electric motor (i think it was originally on a vehical)
Anyhow, the motor has been fitted to a flat plate on the top of the compressor that's not wide enough for the motors foot. So theyve just used two bolts on one side, and the other end of the foot hangs off the side of the compressor.
Ill have to take some photos, but its not pretty...
Anyhow, i took off the motor to fit a new belt today, and i cant get it to stay parallel to the rest of the job now. The belt pulls it around at an angle, and, besides, when its running, its all jumping about some, on account of only being half attached.
So, to the question -
I realise this is child's play for a lot of you, but what's the best way to mount this?
The compressor has a flat (plate) 'shelf' on the top of the tank, where the pump mounts, and where the motor needs to mount. But the motor needs to be offset (so about 1/3 of its foot is over the eged of the shelf) so its pulley aligns with the compressors pulley.
Is my simplest way to weld on a plate large enough to take the motor's foot, on top of the flat top (shelf) that's currently there, and then cut some slots in both it, and the original shelf below it?
Or is there a better way?
I dont have a mill thats good for ferrous here, so im wondering if a thickish alloy plate bolted to the original might do (i can CNC some slots in alloy, rather than butchering it by hand)
Again, this seems like it should be a simple job, and im sure some of you have done loads before - which is why im asking!
Thank you : )
Thank you : )
