Thanks Dcal,Hi, welcome to the forum.
What gun is it?
Any suitably sized compressor will work but there are huge differences in the air requirements for any gun depending on the size of the air cap.
Check the air requirements for the air cap you intend to use and my advice would be to get as big a compressor as you can afford (and run from your electricity supply)
Do you intend to use an air fed mask?
They can use far more air than the spray gun.
That compressor will only run that spray gun (or similar)
It will probably be low pressure so won't be much use for anything else.
I haven't used that type of setup so can't comment if it's any good or not.
A spray gun and separate compressor will be more expensive but will be better and the compressor would be a lot more useful for other stuff.
If it's only for spraying an airless setup would also be worth looking at but I dont know anything much about them either.
What stuff and what type of paint do you want to spray?
Thanks Dcal, I'll have a read up.If you want to spray a car you will need something bigger.
3 hp at least and a 100l tanks size would be OK but you might get away with a 50l tank
You won't get a huge spray gun (or air cap) to work with that but for starting out you don't need (or want) that.
Have you read any of the compressor posts on here?
Also the paint “how to” at the top of the page is worth reading (even if it’s a little out of date)
Have a read of the thread below, there are lots of others.
The Wolf Dakota compressors are good value and well thought of by members on here but there are lots of options at that sort of money.
A decent spray gun can be had for very little money but the hoses, regulators. filters, PPE etc. all add up.
A direct drive compressor will be a bit cheaper but will make a lot more racket and probably won't last as long.
Air compressor - hobby mechanic and painting
Hi, I'm looking to buy an air compressor for my garage for general tool use and eventually once I get through my welding I'd like to use it for painting (going on a course later this year to polish up my hours of youtube learnings). I know I need at least 14CFM and also I need something that...www.mig-welding.co.uk
It wouldn’t even look at it on much more than a couple of panels, the OP is looking towards an HVLP, high volume, low pressure. A ballpark would be 9-15 FAD depending on gun/air cap.It's worth googling about spray guns. I did recently (cos I know naff-all about them) - and you can get guns that run smaller paint nozzles so require less air cfm to operate.
That means it'd take (a bit) longer to paint a given area (but for me the lower volume might actually help a newbie avoid runs etc?).... but of course it means you don't need as huge an air compressor setup.
(I've got a 50-yr-old Ingersoll-Rand 2hp, 1ph, I think 150-Litre Reciever compressor, something like 9cfm I think... & I don't think that would cope with a big spray gun, but I've not tried)
I guessed as much, but it's good to get some confirmation from someone who knows a lot more about itIt wouldn’t even look at it on much more than a couple of panels, the OP is looking towards an HVLP, high volume, low pressure. A ballpark would be 9-15 FAD depending on gun/air cap.
Your 9 cfm is likely piston displacement, and FAD roundabout 2/3 of that.
Thats before air to breathe is even taken into consideration.
