Hi there,
First project thread. Im from Ireland and im making a hydraulic press for my garage.
I do a small bit of work on cars so im only looking at building a midrange press. Around the 12-20T range.
I have the advantage of working in an engineering company that specialises in laser cutting so will look to use that to my advantage.
Iv been looking at this http://www.harborfreight.com/20-ton-shop-press-60603.html as a base/'stealing of the ideas'.
My plan is to use some 6" or 8" stock channel for the upper crossmember and the lower crossmember.
For the side rails i am going to cut some 6/8mm S275 mild steel sheet material, pre-cut the holes and then get it folded on the press.
I am thinking about cutting some 6mm washers to weld around each hole on the sidechannels for extra strenght but Im not sure if thats overkill (or not enough :/)
Any thoughts/ideas criticism shoot away!
Ill hopefully get the parts cut before the weekend as we are closing for 2 weeks holidays. Im also waiting on my new Pprtamig 215 to arrive.
