Got it last week, it was working fine.
Running it from a different socket and now wont start properly. Opened plug to change fuse and see someone has wrapped up the old fuse in foil
I have a HV02 which I think is the modern equivalent of a 15 - mine is also 2.2KW? I bought it from new and there is no way it would start on a 13A plug - the starting inrush is too high - it needs a 16A socket (I have mine on a C curve 16A MCB). I imagine that is why the previous owner bodged the fuse. My guess is that there is nothing wrong with your compressor?
I'm not a sparky but I thought those 16A plugs had to go back to a 16A MCB - otherwise there is no 16A fuse in the system (the 16A plugs do not have a fuse in them like an ordinary domestic 13A plug). I expect a sparky will be along in due course? I have a separate circuit from my Consumer Unit - a single 16A socket running from a 16A C curve MCB.So, should I get a socket fitted next to the compressor with a 30amp supply and then fit a 16amp plug that can be unplugged when compressor needs a service?
This is what a sparky has suggested.
some sparky sugesting putting it on a 30 amp supply when the data plate says 16 amp a dedicated supply on a 16amp c -curve breaker will be all that is needed wired on 2.5mm cableIt worked fine with the foil around the fuse, but then I started using it from a different socket and it starts ok when empty, but when it is cutting in because pressure is getting low, it started struggling to start. So I looked at the fuse and see there was foil around it. Changed the fuse and it blew straight away.
Looking at the electrical box on the top it states 16amp, so I think it needs to be wired into a proper socket or have a 16amp plug on it.
Just wanted to see if anyone else had this problem with the hydrovane?
I had a sparky take a look and he knows nothing about compressors but he suggested fitting a 30amp socket and wiring the compressor straight to it?
Don't want to shell out on this if the compressor is faulty.
Do you know what capacitors I would need?
There are 2 on there but they are both painted black so can not see any info or numbers?
