Hello, I have a Hydrovane 501 compressor that makes a strange sound as it nears shut off pressure. I have had problems with the compressor due to a terrible rebuild from a local shop. Those problems have since been corrected. The last problem was resolved when the oil seal was replaced. Afterwards, the noise started. I thought it may be the internal pressure valve releasing, but the head pressure gauge continues to climb normally when the noise starts. The compressor runs normal until the tank pressure reads 115lbs and then a loud buzzing sound starts. The pressure continues to build as it should and the compressor cycles off at 125lbs. When the compressor cycles back on, the noise does not start again until 115lbs. There is clearly a problem that is causing this loud buzzing sound, but I don't know what it is. I hope some one has some ideas on what this could be.
Thank you for the help
