I have a Hydovane 502 that has been sitting in a (dry) barn for about 7 years as the electricity supply was not up to the job.
I tried to start it as I now have access to a 25 amp supply, to check it out before giving myself a hernia moving it 50 meters onto the building site (Dry, dust free).
As it is raining cats and dogs, I ran a long 6mm twin and earth to it, to check if it was free to rotate. It did, in a clockwise rotation (viewing the end of the motor).
It ran for about two seconds then cut, ran for another two seconds, cut, etc.
The contactor remained engaged during the cycling and there was a "clack" from the motor as if it had some under-voltage protection or other
start protection.
I'm fairly sure my problem is the cable run is much too long, but reading this forum, I am probably lucky that it will not run as it is massively overdue for a service.
As I can't find the manual, that I know I have, and I'm sure it is an owners manual not a service manual anyway, apart from the obvious oil change, what other parts are recommended to re-commission the 502?
Before I bought it, the 502 was running in parallel with a 503 running a couple of CNC milling machines, and was under a service contract.
I believe it to be a good example of a great machine, so I would like to look after it.
I hope you guys can help me and the 502!
start protection.
