weatherman
New Member
- United Kingdom - Hampshire
Hi everyone, I recently have been given a hydrovane hv02 three phase compressor but have been looking to convert it for single phase for use in my home workshop. Before I go ahead and sink money into the wrong parts I thought it would be best to see if anyone here has any experience with a motor swap and rewiring of the controller/starter from 3 phase to single.
I have opened up the control box and there is a single phase transformer that has 240 and 400v inputs so swapping the input for 240v and rewiring the two contactors for single phase should take care of the motor start side of things right? I found a user manual online with the instructions for single phase input but no info on the motor connections. None of the circuit diagrams for the single phase hv02 are publicly available so I'm a little stumped but hopefully will work it out.
Here is one of the motors I have found that I think will fit correctly. Unfortunately I have not found a compatible 2.2kw single phase web motor with the flange mount needed but I think this would work. AMTECS motor 2.2kw - The motor that I think required is a 2.2kw 2 pole 2.2kw 90 frame motor.
If anyone here has had any experience with performing this conversion your pointers will be much appreciated. There are a few threads knocking around with people talking about performing the conversion so I know it is definitely possible.
Thanks
Thanks
