DAPPH
as dyslexik as I'm daft
Towards the end of the recent storms my trusty 10 yr old Hyundai HY 3000Sel HX14 inverter suitcase generator ( in a stout weather proof ply 360 degree locking castored case ) decided not to play on the electric start at 19.15 hrs. whilst it pee'd down in stair rod style rain .. no problem .... use the pull start , it started with ease on less than 1/3 of the pull cord .
Later on I stopped it before it ran out of fuel to check the oil and to refill the tank & check every thing is looking OK , it restarted with ease once again . Did the same again at 22.30 ready for the next morning without power and it failed to pull over easily & wouldn't fire up or start . Plenty of clean oil showing on the dipstick but a slight whiff of melted plastic met me when I opened the carb side panel . So I used a customers newly repaired genny instead . " Load testing Sir ........honest!
Fully cool the next morning , the genny was still almost as tight to try and pull over even with then spark plug removed .
OK......... things need stripping to check it's not a problem with the starter motor , the pull start recoil stuff or even worse the engine or generator .
I got the hand book out , no info on stripping the two halves of the plastic case .
Couldn't find any You Tube videos showing things like that either .
Have any of you guys or gals successfully split the casings and worked on such a suitcase genny , if so would you tell me what you did after draining off the oil & emptying the fuel tank please ? .
