You haven't missed much, I could make a better and faster joint with a 4mm iron powder rod, there were also gravity welding devices, an electrode mounted on an arm that held a conventional electrode angle and fed the rod as it burned away, that soon got thrown in the corner with the other junk as well,Heard about but never seen it done.
Yes but put it in the context of welding deck plates on oil tankers and making it an automated, consistent process and these machines were a step forward. As I understand it the Japanese were big on this in the late 60s and they used 7024 rods. One operative could keep half a dozen machines fed and be paid not too much. I'm sure TechnicAl will correct any points I've made which are in error."Good way to do it quick".
Really? Seems to take a lot more faffing about than just striking up and running a weld.
Welding the bottom of the hull and the vertical sections would be a different story, but the owners of the shipyards would be into cost savings and consistency and they'd be significant on the flat sections of a big ship where automation could be fairly easily applied. The Japanese were very much into Demmings' ideas of quality. Also a lot of this is about having a good design you can produce with a minimum of variability and skilled labour, and which works pretty well. If you can make something pretty good, cheaply enough, it doesn't have to be the best that can be achieved to be a success.
I believe these days that they use robots using flux cored wire with gas for as much as they can, and that's quite a lot. Let's face it, if you want to build a ship of given standard, you want to minimise the use of skilled labour and use machines as much as you can. Far less messy. If you could pay a magician £500,000 to magic the welds together on a big ship, it would be a bargain, but you'd be casting round for magicians who worked cheaper. That's pretty much the story of welding replacing riveting.
What machines? I'm talking about what them are doing in the video.
Ha ha yeah I'd imagine not the place to do it really. "I don't need a welding mask sir but I've got me fire proof boots on"Ive never seen firecracker used as a production method........just a trick really
having said that something similar was blamed for a big failure on an oil rig. It wasnt supposed to happen but someone cutting corners.
did you try itI actually thought the video was a fake because I would have expected the rod would have burned away too quickly to produce that much weld fill also there would have been a good chance of the slag running before the weld pool causing slag inclusions.
the same as most of us, ive said I'm going to try stuff and never get round to itNot yet Paul, when I did have the time I forgot. One of these days.
