Ali The Farmer
New Member
Hello all....
I am trying to construct a barn roof and having great fun/difficulties. The roof will have 7m long galvanized roof sheeting, supported by box profile steel supports.
Currently I am trying to arc weld 2mm thick 40mm x 40mm box profile on to 2mm thick 60mm x 40mm sections. The air temp is 25c, the electrodes are dry, numbered 6013 (2.5mm), and the Invertech 181 rig I am using is set at 70amps (electrode box says 60-90 for 2.5mm).
I have read all the advice, but most of time, the bead is non existent once cleaned up. Initially, it looks great, but what I end up with is a lot of slag, which after chipping off, I find I only have single large spots of weld on each base metal, but hardly any spots of join, or none at all.
See images below:
Can any of you more experienced guys here help me with some advice on what I am doing wrong?
Many many thanks in anticipation!
See images below:
