Noods
- Ipswich
Ref my earlier posting I've managed to finish off the last few pieces of work on my hacksaw project.. Now got a couple of positions located on the crossbar of the hacksaw to allow positioning of weight as req.. Also fitted a six mm plate onto bench to give me the ability to have a level work surface for my drill clamp I've also marked out angles and made it so the drill press can easily rotate to allow accurate mitre cuts.. I got a trend digital level and angle finder to help do this which was superb.. It was also brilliant for getting the blade spot on verticaly too..
Everything, the hacksaw mounts, the motor and the drill press are mounted through the worktop and threaded into some 70x70mm box section to give it good stability and ridgidity ...
Just wish I had a nice little milling machine now, the number of times I've needed to cut accurate slots and had to struggle to do it by hand..
