Hi all,
I am having a problem with my welds being consistent.
Basically i am trying to spot weld on 1mm sheet body panels with 0.6m wire.
I have set up the welder on a off cut of the repair panel and i get really nice welds with the correct penetration and a good sound.
I then go to the car and put down a couple of welds, fine no problem. But every so often for no reason i will start to weld a spot weld and it starts to pop and fart. The wire just shoots back to the tip of the welder and sometimes welds itself to the end of the welder.
I have found that if i keep the welder going through this popping stage after a second or two it will run fine and weld a nice spot weld, But not always.
I have tried cleaning the panels again with a wire wheel and sometimes it helps but not always. I have also tried to wipe the panels before welding with white spirit to try removing any grease or oils but again inconsistence with the spot welds.
I’m getting really disheartened with the welding at the moment and am getting really hacked off with not being able to resolve this problem.
Any help would be much appreciated.
Chris
Chris
