I have a compressor with a small tank. I have an old tank, twice as big from a compressor that broke its crank, linked to the smaller one via an on/off valve.
Lets take my sheet nibbler (toe nail cuttings type) as an example:-
16g ally with the smaller tank cuts 500mm and then takes 1 minute to re-fill.
With the larger tank attached, now 3 times the volume, it will cut 1000mm and take 3 minutes to re-fill.
A re-fill is from when the nibbler stops @ 65psi to 120psi.
So twice as much cutting with three times the wait to fill up.
If all you wish to do is, i.e. blow the dirt from a thread, then a quick fill is better.
The size of the tank is nothing to do with the power of the compressor. What is the ultimate is bigger motor and higher CFM.
Another example is my nut runner. It will undo 5 wheel nuts and be back up to pressure by the time I've moved to the next wheel.
Just about perfect for me, although when this one gives up I will look for a bigger CFM. ( or whatever it is in metric )
HTH
Paul G
I think the hardest part is getting the valve off, I got one off before but it was a smaller butane bottle, the valve on this 47kg big bottle is tight, I've ordered big stilsons to hopefully remove it!
I just lay the bottle on its side and put a length of bar through the collar, wedged against the ground - stood on the stillsons and valve loosened no probs.You can hold the bottle perfectly with a bar, some rope and a bit of rubber (like a section of inner tube).
