pondy
- chedburgh, suffolk. uk
does anyone have experiance with this gun, i have recently brought it after much research but after using it for a few weeks have been a little let down. meant to have around 1000nm nut busting torque but a few times i have been unable to undo wheel bolts and have had to use a breaker bar.
am a technical at a main dealer so this is getting used everyday, have a large ingersoll rand compressor (will unload pics), steel air pipes come from its tank to a pcl end at each of the 15 ramps, from mine i run a short air line to a water trap then have my main rubber air line into this, all using 1/4 pcl ends, regualtor reads 90psi when operating. am unsure if the air line size is causing the lack of power or if the figures IR gives are just way over rated?
sam
sam
