steviec_lj
Rust Welding Professional
- Barnetby, N.Lincs
Hi guys,
Currently in the process of rewiring the garage at the new place we took over a couple of months ago. Thankfully the garage has an 9' by 11' room at the back, that apart from lacking an internal roof, has become a small store room for a business sideline, and the new home for the afore mentioned compressor.
This is so that the main garage isn't quite as loud as it would be if the compressor was simply stuck in the original spot I had planned for it. Now, the question is;
Is it possible for me to mount the cylinder pressure regulator, which is still currently attached securely to the compressor receiver, on the main garage side of the breeze block wall of the internal room, along with the pressure switch, etc?
This will all be connected through a DOL Starter and 32a Rotary Isolator in the main garage area.
OR
Am I better off leaving the cylinder pressure regulator on the compressor as is, and installing the DOL Starter and 32a Rotary Isolator in the positions I have planned?
Thanks in advance,
Steve
OR
Thanks in advance,
Steve
