Hi All,
Quick question, on Saturday put together the pieces of metal that are pre cut etc from a company called YRM and spot welded them together first real proper job with the welder, other than tinkering fairly happy with the end results but and it is a big but:
on the original inner wing, where the outer wing is fixed by a piece of angle, this was screwed into clips that were fitted in the top of the inner wing, you had a rectangle hole that you used to position the clip over a round hole and then the screw would go through the hole into the clip and become fastened.
Well the new inner wings do not have the holes either the round hole or the rectangle hole, I realise I could just drill and put a self taper in but I wonder how you make the rectangle hole or is it punched in whilst a flat sheet (now its a U shape)?
