The inner wheel arch has an outer 2-inch with no stonechip (just a flaking black cellulose), the rest is entirely rubbery stonechip.
3M clean-n-strip disc...
- Black cellulose area had thin film of rust, but easily achieved bright steel with a few pinholes coinciding oddly enough with tiny dents!
- Rubbery stonechip area had perfect bright metal, no corrosion undercut.
I plan on...
- Vactan (tannic acid corrosion stopper) to kill any corrosion in the pinholes
- Clean-n-strip the Vactan off, leaving neutralised pinholes
- Fosroc Galvafroid Zinc brushed (as I have no Bondaprimer Zinc spray left)
- Galvanised paint primer (yellow)
- Hammerite Stonechip Shield (grey, overpaintable)
Instead of Galvafroid I could use Plastikote 90% Zinc aerosol, but prefer to use that "between jobs through bad weather". Zinc must contact base metal, any insulating effect eliminates its electrochemical protection (and galvafroid does work surprisingly well from experience).
Q - If I ever have to weld again, how easy is it to remove Hammerite Stonechip Shield?
I suspect it will be easy to remove because of the underlying galvafroid will be mechanically weak in shear, I just want an impact overcoating. Most would use Lechsys 2k Zinc Epoxy but I am wary of an epoxy near where I may need to do future welding - why add more work before I am done :-)
I plan on...
