Hi guys. I run a compressor in the back of my van powering a tyre machine and air tools.
The compressor is driven by a Honda clone gx160, the exhaust exits through a pipe that goes through a hole in my wheel arch.
I have recently brought an electric start kit for it, which works great. The idea is for me to wire the switch in the cab, so I can start the compressor on route to customers address, so it is full when I get there (instead of waiting when I'm there, making loads of noise. The thing is, I want to be able to adjust the rpm manually from the cab.
I'm hoping this May work somehow (don't know if it's just for 4 cyl engines??? )
http://www.ebay.co.uk/itm/Car-Motor...easure-Meter-5-9999-RPM-Red-LED-/261202456790 so that I can monitor rpm? S this possible?
Also, what systems are available to cut the engine back to idle once desired psi is reached? My engine is de governed. I have seen the American videos on YouTube showing bull whip contraptions?
I was wondering if I could go DIY (and here's the part you will laugh at). I was thinking that I could wire an old electric window motor up to pull the cable back and forth, add a few resistors to make it run very slow?
Now I've said it it sounds even more stupid, so maybe I'll stick with asking if that tachometer would work!
Cheers.
Cheers.
