Ped
I've recently upgraded my Hydrovane compressor to a higher cfm by fitting a faster motor. I'm told this should be ok providing I don't try and run it without a tank.
It seems to work fine and produces a lot more air but the water in the tank has increased (maybe not a surprise?) turned yellow and smells like strong cherry cola!
I serviced the pump end at the same time as upgrading the motor, replacing the oil, filters and o rings. It hasn't used any oil and the water coming out isn't milky.
The water in the tank wasn't like this before I changed the motor/did the service. Is this just the result of the increase in speed/heat? Or maybe something else?
